my right cornering light stays on after the turn signal has turned off.
This is the first run of the year. It did not have the issue last year when I put it away What can cause that ?
Back behind the cornering lights in the cowling there should be a relay in the wiring harness on each side. Switch them from side to side to see if the problem goes to the other side. If so than the relay on the side that stays on is bad. You can find the cornering lights with relays or complete cornering light kits at (www.mototourinc.com) at a good price.
