I have a 1984 1200 Aspencade. Clutch master cylinder is leaking at the site window. What can be done to fix this? I can't find the part.
First of all, welcome to the forum. Have you tried eBay?
hello mcweaver, welcome to GWOF
you can seal the sight glass with jb weld or if the glass itself is bad you can get a 17mm watch crystal and sand it to fit and jb weld it inplace after removing the old sight glass
Have read you can cut a disk; with a metal lathe; heat clutch;tap in frozen disk.
Used to have name of guy who did this; but can't find.
Triwing
I'd first drain the brake fluid to below the site glass, clean it up to good clean and dry on outside and use a bead of gel super glue around the outside of the glass. After a brief drying time, maybe helped by a hair dryer on low heat, fill it back up to the line on the glass and shazam!
Have I mentioned I'm cheap?:eek::)
