Good Morning Digger: For the 1.7 watt bulbs ( High Beam,Over drive,Cruise set,cruise on, plus a couple more) I used the 658 bulb, not the exact wattage but close. And for the 3.4 watt bulbs (Neutral,Reverse,Side Stand,Low fuel,Oil pressure,speedometer,Tach) I used the 158 bulb again not the exact wattage but very close. I bought these at the local NAPA store. If you are going to replace all the bulbs while you got it tore down, buy a box of 10 of each one of these, you'll use just about all of them, it is way cheaper by the box then buying the bubble packs of two.
There a few that when you take them out the have what looks like a blue Condom on them if you are real careful you might be able to get them off with out tearing them, I was able to save one or two but the rest tore, no big deal, your panel will just be brighter.
If you go to Honda for Condom replacement ones,take the deed to your house and the title to your car. I been told they are very pricey
One more thing to consider. Replace the Phillips screws that hold the mirrors on with bolts. Using a nut drive to tighten and loosen is a lot easier, just a thought.
From the Northwest Corner
Ron
