1 - 15 of 15 Posts
Recently bought a 03 1800, are there supposed to be rubber pads on the ends that touch the road?
Nope, just metal.
Welcome to the forum from Pa. DK is correct. Just metal...
welcome to GWOF from Maryland
Now all I have to do is try to get it up on the stand. Not to easy on a smooth garage floor. Watched a video looked alot easier than reality
I know what you mean.....The key is to:
1. Make sure you use your heal and not your foot.
2. Push the stand to the ground and straighten the bike until it balances on the stand. Feels like your going to push it over, but your not.
3. Once you get it balanced its ready to straighten the leg and pull.
Good Luck
hello nypd, welcome to GWOF. put more effort into pushing down with your leg than pulling up with your arms and it will pop right up on the stand
Having your rear preload setting at 25 really helps. Also, if you make the switch to a larger 70 series tire when yours wears out, it will help tremendously. I agree, sometimes my bike just doesn't want to go up on the center stand without a fight.
I have a bad back and found putting a piece of 1/2 to 5/8 inch wood under the back wheel really help. I have a piece secured to the garage floor where I park the bike. also have a small piece in the saddle bag for when I'm on the road.
Try it, it really helps.
:cool: I have a piece of 12" x 14" rubber pad that I place the center-stand legs on to keep them from perhaps slipping. It works for me.;)
Another helpful trick for me when I first got my bike was to face slightly forward, rather than at a 90 degree angle to the bike. Made all the difference.
I've found that the method of getting the Wing on the center stand for me is:
Left hand on the handlebar (left side of bike), Right hand on the passenger seat grip.
Right foot centered on the center-stand and depressed.
Slowly push the Wing to the right while keeping the center stand depressed until the stand makes contact with the ground.
Once the center stand is in contact with the ground, press down hard on the center stand while pulling the Wing backwards with the right hand (still on the passenger seat grip) until the Wing is on the center stand. You may have to make more than one attempt, but with practice you'll be able to do it in on fluid motion.
Do not attempt to pull the Wing on the center stand by using both hands to pull the bike on the stand.
1 - 15 of 15 Posts
