1 - 17 of 17 Posts
Ok here is the story and i'm sure you will all hate me because this involves me "dropping" my bike. Was hauling a can of gear oil on the back along a highway the can blew off went to pick it up and the bike fell over while running. Picked the bike up and it didn't start with starter. Tried to "bump" start it next and that didn't work. Tried removing the spark plugs and dropping into 6th gear to no avail.
Bear in mind this bike was running and full on oil when it fell over. I have it in the shop right now but the mechanic i am having it fixed by is an idiot i think and i may just try and fix it myself.
Any thoughts guys as to why it would freeze and how to fix it? I'm scared to hear "new engine" because it was my first day of owning the thing and from what i have seen engines are far from cheep even that old.
By 'freeze', do you mean it won't turn over at all?
How long was it on it's side? Did it turn when you tried the bump start?
was on it's side a few seconds till i could get it up and it did not turn over when i tried to bump start it about 30 seconds later. The throttle did not remain open when it tipped over the engine died almost instantly when it fell.
Is there any physical damage on the engine case?
Is there a bank angle sensor on your bike like there is on the Goldwing??
I would love to help, but can't make cents or dollars out of what has happened. For a motor to lock up, usually means some thing like a valve has dropped and locked the piston up from getting to the top of the bore. If this was the case if you put it in gear and pushed the bike back a bit the engine would turn a bit until it got to the top of the bore again and came against the valve again. A drop shouldn't have anything to do with that. A motor may lock up if it has no coolant or oil. A drop will not do that. The belts could break and have the valves met up with the pistons and lock up the motor. A drop shouldn't do that. On old car's a starter can lock into the flywheel. A hit with the hammer can release it. I don't think this will be much help but they are my thoughts. Eric
Discussion Starter · #11 ·
But would that cause the gears as well to stick when bump starting? If so that wowould make sense. This all is so confusing to me. Please if anyone has any idea at all about it or thoughts feel free to post. One thing I did note as odd was when I was trying to bump start it was very hard to get the bike in gear. I had to hit the shifted 5 or 6 times to get into any gear with or without the clutch engaged.
I assume it fell on the left side?
What does it do when you pull the clutch in and try the starter?
Discussion Starter · #13 ·
No it fell on its right side on a slightly downword slope onto some decent size rocks. There are scraches on crank case but no dents. Fall broke mirror off and turn signal. Fall was only from bike to ground no great hight.
Is there any damage on the cylinder?
The only other thing is if it pushed the clutch cover in against the clutch pack.
Discussion Starter · #17 ·
the mechanic i took the bike to at long last got his act together and took a look at the bike. He turned the crank lever i think? he took off the crank case and turned that and popped it loose but now there is a rattling inside. he thinks that when i purchased it that there were already shavings in the bottom of it and that is what stopped the motor from turning and whatnot. at least that is what he thinks. he has yet to drain the oil and fix the bike.
1 - 17 of 17 Posts
