Hello all,
Just received my GL2WAY CB radio and antenna and I have a question for ya'll. The antenna instructions say to mount the antenna and to run the antenna cable through a hole in the left side of the trunk. Then, simply connect the antenna to the antenna connector.
On the 2012 GL2WAY, the antenna connector is located on the radio in the compartment in the lower trunk area. There is no reference to running the cable back into the right side of the trunk.
Has anyone installed this setup and can tell me how you did it? Did you simply run the antenna cable across the inside of the trunk from left to right? Did you run the cable through the left side to under the seat and then back into the right side of the trunk?
Thanks for the help. I have sent emails to GL2WAY and ADD-ON who made the antenna. Waiting on a reply but thought it might be quicker to check here...
Thanks,
Jeff
Thanks,
Jeff
