Hi all.I would appreciate if someone could tell me where i can get a "valve adj cap"for my 1982 Goldwing GL1100A.It goes on the stator cover and prevents the oil from coming out of it.Thanks in advance.
There will be some one along shortly that can point you in the right direction. It's just not me that can do it.sorry.
Did a pretty thorough look through both parts and service manual and haven't located it, sorry. Hopefully somebody has an idea.
Is it the clear plastic plug that is used for timing the engine? I remember those for older HDs.
Have found the part and its numbers.
Honda Code 0630681
Part#07999-3710001
Timing Inspection Plug.
Discussion Starter #6
no,its not that.the part screws into the stator cover that is in the rear of the engine.if you google about how to take off a stator cover for my bike you may get a pic of it.thankyou anyways :)
If memory serves me correctly, that is called a valve adjuster cap used on many older and even some newer Honda bikes. Gold Wings also use it for final drive filler plug. About $7.00 at Honda. Buy at least 2 cause you will need one again soon if you do any work on your own bike. They are quite fragile and break easily. When I rode 4 cylinder air cooled Hondas I kept several on hand for valve adjusting as they break easily.
