21 - 33 of 33 Posts
· Registered
Discussion Starter · #22 ·
I was able to repair a similar unit on an 89 K100. There are a couple of capacitors that tend to go bad. On that K bile, I was able to do it for $10 or so. Of course the large paper capacitors were a special order item, but I was able to get them from Digikey. It's been my experience that a lot of electronics get tossed when a couple of new capacitors could salvage them easily. Since caps have atomic level "moving" parts, they do wear out over time.
If you have any skill with a soldering iron, you might try looking for any funny looking capacitors to replace, or any can type capacitors that show any sign of deformation. It could be risky, but if it's already not working, might be worth a try.
If you have a working ICU. I'm willing to trade 2 of my defective ICU's.
The part number Glblinded posted is what you are looking for.
Do you have a picture of the old
Do you have a picture of the old one?
Yes.
· Registered
quote "
julimike54 said:
Above is the name of the item you're looking for, not ECM, it should be ICU
Have you tried Straightwings....
StraightWings
I thought they're the same.
quote"
To me it is a matter of what the factory calls the unit and even then they can be inconsistent. The name I used is what it is labeled in the electrical factory manual, the parts manual calls it an Igniter Unit. The 'black box' in the Gl1200 I/A is only analyzing inputs to set spark stuff and it isn't doing near what ECMs do in newer machines. Part of the variations are the 1200 was the first Wing to utilize a black box, it was the mid 80s and this stuff was just getting going. Today there are so many black boxes (in vehicles) they all have different names and the list seems to grow with each new model that comes out. Good luck
· Registered
2012 gl1800
The OP says he has 2 defective units. Something happened when he reversed the connections on the starter relay. Wondering how he knows the igniter unit is the problem without trying a known good one. Hard to tell exactly what happened with the reverse polarity.
Here is a company that sells new aftermarket ones.
· Moderator
Perfect. Glad to see availability.
· Registered
Discussion Starter · #27 ·
I have electrical trouble shooting manual for gl 1200A. My bike cranks but won't start. There is no spark on the spark plugs. Coils tested according to specs. The diode, battery, and sparkplugs are new. Manual says that to test for the CDI or ICU to know if it's working, connect the negative pole of the digital meter to battery negative pole and the positive pole end of the meter to the disconnected connector ( wiring side) of the ignition coil and start the engine. If there is no spark, the CDI is defective.
· Registered
2012 gl1800
I sent a link for a brand new CDI.
After all the extensive troubleshooting, you never mentioned checking the kill switch. The 1200 will crank and not start if the switch is off or defective. Do you have the 12 volt going to the control unit?
I no longer have the manual for my 1200, so this is just a guess.
· Registered
Discussion Starter · #29 ·
Tnx for the links for CDI. The kill switch is in run position. I'll check if there is voltage running on it. I just thought of it yesterday. I want to make sure (WITH YOUR HELP) that there is nothing I've missed before buying the new CDI.
I tested the kill switch. It's good. Is there anything else that I missed which prevents the sptark plugs to spark? I just don't want to buy expensive ICU if that is not the cause of no spark.
· Registered
2012 gl1800
Do you have 12 volts at the kill switch? 12 volts while on and 0 when off.
I'm not sure since I don't have my manual anymore, but it may be the pulse generator located under the timing belt cover. Do you have 12 volts going to the ICU?
Hopefully someone familiar with a 1200 will respond. It's been 20 years since I had my '85.
· Registered
Discussion Starter · #31 ·
I have 11.76 volts going to the ignition coil. At the kill switch I have 0.17 volts open (0) position while 0.00 at run position. Battery voltage is 13.7 volts.
Correction on earlier reply. I got 6.67 volts at the kill switch.
· Registered
2012 gl1800
One thing I just noticed on their site,
"Please email us about the CDI test and repair and stator rewind service."
They may be able to repair one of your old ones for less $$$
21 - 33 of 33 Posts
