hellow I am just wondering if it is possible to get the cams reversed
on a 87 1200 cc My prob is it would seem the egsuast is coming throught the carbs instead of out the tail pipe .
any help is much app.
lv breezer
hello and welcome to GWOF lv breezer, have you had the cams out or changed timing belts
I've never played with a cycle motor but if this were a car, it's not enough for the timing marks to just be aligned, the #1 cylinder must also be at TDC on the compression stroke.
Hoss
Its possiable to mix the cams--- but first make sure your at TDC and that #1 is in the correct position --- if you have to tear down the heads again -- watch your parts numbers --- I can give them to you if you need thm
to all how helped me along the way thankyou very much.
I have figured out what was wrong ,timming off 180.
once again thankyou all.
lv breezer
