1 - 19 of 19 Posts
I read the pro's and con's concerning to "brace" the Wing forks or not. I decided the only way to determine if the SuperBrace would do what it claimed was to try it out. I ordered a Black Powder Coated Billet SuperBrace from CycleGiant.com/WingStuff.com and had it installed today. The Brace was on sale.
The Motorcycle shop charged 1/2 hr. labor to install the SuperBrace, and also checked out a minor electrical problem for me at the same time.
Rode 40+ miles back home. The Wing's handling was a tad stiffer, in a good way. To me the handling was not as mushy as pre Brace. When stopping for gas, I was able to tool around the gas pumps much easier than I could before, the Wing's low speed handling was much better for me.
In summary, the SuperBrace, at sale price :), has improved my Wings handling.
Ride Safe,
T-Rex
Glad it performed as you hoped/expected. I had one on my 98 GL1500 and found it helped in slow speed handling. I don't have one on the GL1800 yet because I haven't noticed the same problem.
I'm interested in installing one of these on my bike. How do they install, is it something a pretty good shade tree mechanic can do in his garage?
Haven't done one myself, but it just bolts on with a squeeze clamp like set up. It replaces the plastic chrome fork seal covers which do nothing but look chrome.
jay, Here is a copy of the actual installation instructions from Superbrace for the 1800. Even though PDF says to 2006 the description on website says 2010.
http://www.superbrace.com/install/2318.pdf
Shadetree can handle it no problem.
I couldn't have said it better, because I didn't. You da man that showed the plan so we could all understand the procedure at hand.
Actually if you are talking about the chrome fork Chaps, they do serve a purpose. They protect the area above the folk seal from bug splatter.
Dried bugs on the fork tubes are murder on the seals. Also they look really cool. ;)
Had a Superbrace on my '84, huge inprovement in handling. The stock brace was shot (free-play in the mount holes) so that's likely what made it seem so good.
Thanks for answering my questions. After posting last night I did a google search and found a video of an install on Blackwing braces, I'm sure the procedure is the same for any brace on the market.
Ride Safe,
T-Rex
I've got one on my 1989 GL1500. It does stiffen things a tad but with a trike kit, I needed a little stiffer, especially for sharp turns. While it doesn't turn a GW into a new bike, it may help alleviate some complaints people might have. It's worth the $55 or so that CycleGiant sells'em for, which is like $20 cheaper than most others.
I just ordered my Superbrace from Wingstuff. Can't wait to see how it makes my bike handle.
I think I better call it quits on ordering goodies for the GW for a while or the Missus will take away my credit card.
Discussion Starter · #15 ·
I've read that folks that have a bit of mechanical wherewithall can install a fork brace in ten minutes; however, mechanical I'm not...I opted for the 1/2 hr labor charge. Yesterday I rode about 98 miles under varied conditions, highway, heavy traffic, neighborhood, etc. I believe the Wing does handle better with the fork brace, but that's just my opinion. The mechanic who installed the fork brace did give my the chrome/plastic guards that he removed. Good Luck.
Just finished putting it on the bike, took about 20 minutes, wouldn't have taken that long but a friend stopped to look at the bike and had to get the whole tour.
Not a problem. Only four bolts torqued to 10 ft.lbs.. You remove the useless plastic trim. Install the brace at the top of the forks where the tubes slide in and out and torque the four bolts as mentioned above and then install the trim pieces on each side and your done. Enjoy!!!!!
I haven't road tested it yet, have to take the Missus in to town first, I'll give my report later.
I just rode mine yesterday evening for the first time after installing the brace. I noticed an improvement on making a right turn from a stop. I'm going on a long ride today and will find out for sure if there is a big difference.
Interesting....
You say you put a brace on your trike, but the picture (over-sized btw) shows a bike!
1 - 19 of 19 Posts
