some people have tried to bleed the brakes on their Wings and have soft pedals after they are done. There is a set sequence in the way they have to be done, make sure you do it that way or it's useless. Here it is
Front Brake Reservoir
1: Front Right Brake Upper Bleeder Valve 8mm
2: Front Left Brake Middle/lower Bleeder Valve 10mm
Rear Reservoir (under right side chrome)
1: Front Left Brake Upper Bleeder Valve 8mm
2: Front Right Brake Lower Bleeder Valve 10mm
3: Rear Brake Lower Bleeder Valve 8mm
4: Anti-Dive: bleeder valve on top 10mm
5: Rear Brake Upper Bleeder Valve 10mm
Joe, you're amazing! I'm sure that will help out a lot of home wrenches with brake woes.
Thanks, I hope it will save someone some headaches in the future
Chopin
How about you doing a How to change the Low beans ?
There we our second How to
