1 - 12 of 12 Posts
I have a 92 1500SE. End of riding season last year brake pedal started to get very soft. This spring installed new progressive springs in front and 416's on the rear. While apart changed pads front and rear and greased slider pins. Bled system from front to rear as aways, no air. Still no firmness to pedal. Since the bike is 20 years old the local dealership told be to install a rebuild kit in the rear master cylinder. Done that and bench bled the master cylinder and then the system. Still no firmness to pedal. Checked the thickness of the rotors and found them to be within limits. Checked all lines and fittings with no problems found. Had this bike for 9 years and do my own repair and maintenance and never had this much trouble with the brake system. What am I overlooking? :mad::confused:
the left front brake is linked to the rear brake, bleed the rear first the the left front
Sorry Doc.:eek: Just checked the Honda Manual they say to bleed the left front first then the rear.
Might try this on the foot brake.
Pump it up till it gets firm, hold it there and hang a weight off the pedal and let it set over night.
darn, got it backwards again
so what about the calipers, is there a frozen or sticking piston ( s )
I have an '89 GL1500. One of the repairs I had made recently was a rebuild of the rear caliper because I went from some back brake to zero. The guy rebuilt the caliper, changed out brake fluids, replaced the pads, and raised the pedal a notch or so - $500 job. He says I need new discs, but that the rear is good 'nuf to pass a state inspection for now. That is, the disc is within spec, but barely so; he says i need a new one to realize the full braking potential.
I now have OK back brakes; I can stop well, but they still don't feel as tight as my Harley UC or the VTX1800 that preceded it, but they stop the bike just fine.
Well, shoot, Teal. Everything is cool with the rear pedal linkage and master cylinder pushrod?
The rubber line(s) might be bad. When they go bad, they will expand under pressure and cause a soft feel.
Here is the reason for my reply.
Oh, that's right, you're another moron that won't return anyway!
1 - 12 of 12 Posts
