Mother Honda does what they do for a reason, doesn't mean we can't modify it! Ordered and installed the Show Chrome brake light conversion wire harness that makes the lower marker light to work also as a brake light. Easy enough to do, took more time to remove and replace than to run the wires. I've said before the wing has the best rear lighting of any bike out there, this makes it even better. If you can't see this in front of you, you need to stop driving!
