Help, this is driving me nuts, (short trip). I have a 1991 GL1500 SE. Coming home the other day, the turn signals quit working, both left and right. Got home and sprayed some contact cleaner in the switch housing. Even in the hazard switch. They started working. The hazards not quite so well. Figured I was ok. Next day signals work fine until on the way home. Started out ok, but then nothing. Got home, pulled in garage and then they work. I got to the connector blocks on both sides and pulled them loose, but was having trouble trying to run on ohm test. Fought with connectors and got them back together. Hazards worked but no turn signals by themselves. Waited a bit as I was cleaning up and tried the signals again. They worked but no hazards. Seems like I can start out with them ok, then during ride they die. Possible loose wire somewhere, but why would they change when bike is just sitting still?
Any help or guidance would be appreciated.
Thanks,
Harry Kelley
Thanks,
Harry Kelley
