got my belly pan from wingstuff about 4 oclock today,went to the unheated garage(25 degrees here in huntington in.)at 6 oclock to install it.took about 10 mins. to prep(2 bottom fairing bolts each side,and remove plastic coating from both pan pieces)then 10-12mins. to install.no problems,except it seems to be looser at the back by the center stand and when i tap on it seems to rattle.will i hear this when i ride?if so,any fix suggestions?any experiences with the belly pan would be greatly appreciated!!by the way it is two piece vented.thanks to all,and to all a great safe ride!!
