I have a 82 interstate and I want to change the yellow turn signal lenses on the bags to be red. Has any one seen where you can get turn signal replacement lenses?
Be careful of you local laws, many locations require turn signals to be amber.
Discussion Starter #4
read turn signal lens color
Thanks for thinking of that
So I checked the Michigan law and this is what I found
MICHIGAN VEHICLE CODE (EXCERPT)
Act 300 of 1949
257.689 Clearance and marker lamps and reflectors; color.
Sec. 689.
(a) Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
(b) Rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
(c) All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except the stop light or other signal device, which may be red or amber, and except that the light illuminating the license plate shall be white.
