1 - 3 of 3 Posts
Hi guys, I made this tool to get at the bolt at the back of the alternator. Maybe it was done before I don't know, anyways what I use is one of those spring gadget to grab a drop screw, copper pipe, and a socket fitting. Easy to make, solder the pipes and slip in the outer spring ( I took the inners out ) in the pipe and push the socket adapt in the spring, voilà. Once you slack the bolt with the ratchet you go in with this and turn to unscrew, you can push the spring in and out to adjust the length. I think its a good idea I didn't try it yet, but I'm shure it should work.
Good Ole "Ameri.......Oops wait...Canadian Ingenuity.":super:
As a Plumbing/HVAC guy I'm really admiring your soldering.:idea::applause:
1 - 3 of 3 Posts
