I'll check into that. Thanks!Compufire now makes a high output alternator for the GL1800, as well as the 1500.
If that's the only difference, I'll only do the swap if I begin to have issues with the current alternator. Thanks for the info.Not sure that the '06 and newer models have all that much more output than the '01-'05 did. They are rated marginally higher (.2 kw) but at 5000 rpm and not 2400 like the earlier ones were. They may be more efficient however, with less resistance to them; but again the differences are marginal.
