1 - 15 of 15 Posts
My 99 GL1500 is not charging. I have taken the alternator off and it checks good at a repair shop. The battery has also been checked and it checks good also. Any help would be appreciated.
Did the shop do a load test on the battery or just voltage? Oh and by the way, welcome to the site.
First, welcome to the forum from Pa. Do you have any aftermarket accessories on your Wing that could be causing a problem? Have you checked the wiring and grounds?
Thanks to both who have welcomed me. My Dad bought the bike new, when he passed in 03 I sold mine and kept his. It has always been garage kept except when on a few trips and has 36K miles. Air horns are the only aftermarket produsts and they are temporilary disconnected. I cannot find corrosion anywhere. Except for a little dust under the side covers it looks new. Just did a ground check with meter and it is good.
Because the grounds look good with the meter doesn't mean the grounds are good. Check your grounds from the battery to the engine and frame and clean them.
Discussion Starter · #8 ·
I feel certain the connections are all good but will go over them. The alternator charges on the test stand but won't on the bike. In both cases the alternator is not hot so I don't think it is diode failure.
Basics! Place a volt meter across the battery after giving it a good charge. Should read about 12 volts. Then ccrank the bike and the meter should not fall below 9 or 10 volts. (Battey bad if it falls below that) With bike running you should get about 13.5 to 14 volts. (If not look at the charging system. First off check all wires and cables to make sure they are clean and tight.
I replaced the alternator and all is well. I was told the old alternator was good, but it wasn't. Thanks to all who posted a reply.
who checked the alternator for you
Glad you found your problem. Now you can get back to riding. Ride safe..
1 - 15 of 15 Posts
