where does the rear air shocks get their air from on a 1982 goldwing is there a air valve where you can add air and if so where is it or does have its own built in air pump with auto level and if so where is it?
When you find it Willy, be careful when you increase the pressure, there isn't a lot of volume in those shocks.
under the right side cover, its best to use a pump for bicycle tires
detdr is absolutely right. DO NOT use a service station hose. It takes about a nanosecond to dump way too much air in there. I speak from experience.
Strat
