Have to ask Carl,because learned about this myself on here until i had gotten my manuals.Do you have ignition in "P" position,and using "outlet" button,in which no pressure reading will be displayed,just compressor will run to air hose.Should not be adding air to shock,if doing this. Page 24 in my owners manual.Just double checked my 94SE to make sure.Worked as stated. If doing this and having problem,let me know,i will try to help.But,sounds to me like solenoid itself is stuck,if you are using per manual.
