1 - 19 of 19 Posts
I am new to adding things onto the Goldwing. I checked the forum and it looks like Honda has a factory kit for an accessory outlet. So far all the installation tips point to installing it in the glove box. I don't like the idea of leaving the compartment open and stored items around if I am going to plug my heated vest into it. I prefer a more accessible location. Has anyone mounted the outlet in some other location? :)
What bike do you have?
You can put your location in your profile and it will show up when you post.
Welcome to the forum.
Yes, the year and model helps. The 1800's have a couple options available to use. One is the fairing pocket, and there is also a pigtail in the trunk. You can also tie into the fuse block behind the left side-cover, there's an accessory terminal there. Finally, you can run a lead direct from the battery (I did that for my wife's Widder vest on the 1200) just be sure to fuse it and protect it from the elements.
I didn't have running lights on my 1800 so I put the plug for the heated gear where that switch would of went, next to the hazard switch.
Hard to tell if " joe in calif " wired the plug into the OEM plug-n-play connector or wired the outlet shown to the battery or a terminal block with a 30 amp fuse. If he used the OEM fog light circuit connection, which is 5 amp max., something is gonna get warm and it probably won't be the rider.
OK, I'll admit it. I'm a smoker. I wanted a lighter to use so wind wouldn't be a problem. I installed the socket in the left box. A quick and easy job. Then velcroed a multi socket/lighter unit to the top of the left box cover. Yes, I do have a bulky plug in the socket in the box, but now I can plug in my GPS, phone charger, etc without opening the box. Suits my needs nicely.
We know. You left your video camera on. I unplugged mine for that very reason. I was in a chat room with my mom and she surprised me by asking about what appeared to be vapors wafting up from my side of the screen. I told it was a hot cup of coffee. OOPS.
Can you use it with a cigarette lighter? I just bought the kit but haven't installed it yet and the directions that came with it says not to be used for a cigarette lighter.
Yes, I will have to look into that. At least I should be able to power my GPS with it. If I can't use a lighter with it, no big deal. Maybe I'll smoke a little less, I guess thats a good thing.
Thanks,
glen...
Thanks,
glen...
From what I have read most car cig lighter outlets are connected to a 10 amp fuse using 18 gauge wire.
The lighter works fine. And I can use it while the GPS is on or the phone is charging. But not all three at one time. Easy guess how I proved that. DUH
It was an internal fuse within the unit. Had no effect on the bike's electrics at all. Still using it.
I just added a power plug to the left fairing pocket of my 1800, it is a plug and play to a plug just under the pocket. Not sure which fuse it was I started pulling fuses, it turned out to be the Audio/ Accessory fuse which is 15amps. I rarely use the radio and installed this mainly for use with my new Slime compressor if needed. I actually used it the other day to top off the tires with no probems.
Can I remove the 5 amp fuse and put in a 15 amp fuse? It fits, works, but not sure that's OK to do. If I can do that, my installation is done with. I want to run my heated vest and instructions say I need 15 amps. Will the load be OK with how Honda wired it up?
I don't want to do it and then realize I just burnt up my fuse panel.
You would burn up the wire harness if you did that.
A fuse is there to protect the gauge of wire used in the circuit.
1 - 19 of 19 Posts
