Spray the ant. with WD40. Makes the radio waves slide in easier.
Uure you used WD40 not some store brand?Hey didn't work out here, must be too far from the stations, I just pick up a station and it slips right off in no time. Maybe that's your problem too Buzzy
I have a can of Electrical Contact Lube. We'll try it on your bike first.Well, if this works for the AM/FM antenna, I'm going to go full bore and put this on the CB antenna as well! I fully expect a 200% increase in transmission power from my CB with it then not having to push so hard to get the signal out.
Heck, why not just try that new "His and Her" KY lube they are advertising! Just like the name implies, he has his and she has hers and when the two mix? Magic happens!I have a can of Electrical Contact Lube. We'll try it on your bike first.
Boy you got taken.. I got mine for .75 cents a quart...... And it works in either direction......I have some blinker fluid for sale. A buck 2.98 a gallon. Will only work in left turn, sorry am out of right turn fluid.
I've heard things about his set up and it wasn't just a coat hanger. It was the coat as well. Tweed jacket, I think.Buzz
Take the coat hanger off and put the oem antenna back on.
