Hello Wing owners
I have a 95 SE that won't start. I started it last Wed for the first time since last Sept. Let it run on center stand while I put a little air in tires and rode it to patio and shut it off. Wife came out to see rear lights that I finally got to work so I started it up to turn on the lights. Horn, radio,turn signals and every thing worked just fine. Shut it off to feed the face. Went out after supper to go for a little ride and the neutral light didn't come on so it wouldn't start. Every thing else seems to work. I have a manual so after I figured out how to check gear sensor I had to remove lower right fairing to check continuity on the wires and it checked out okay. After checking both starter relays I noticed the neutral light was on. Relay A was working but relay B wasn't. It checked out okay before so I put power to it and it cranked. Looked in manual to see if I could figure out why relay wouldn't work. Tried several things but came up with nothing. Next thing I new the neutral light wasn't on. If I don't get this figured out soon I won't have any hair left. Anbody have any suggestions. Sorry this is so long but tried to explane it the best I could.
Bruce
Bruce
