A set from a Valkyrie might work, but you'll have to loose the 'Chamber Protectors' and the pre-muffler chamber, possibly fabricate mounting brackets and rejet and sync the carbs. That's what a Harley is for.:D
Torq Monster exhaust GL 1500
Hi has any one in the UK fitted these and your opinion after fitting them and do you have to have the carb's adjusted
There is a set of SS on e-bay right now, in France somewhere...$300 EU. They have curved pipes in place of the collector box. Looks pretty slick all stainless!
These might do the trick for you:
http://www.torqmasterpipes.com/index.php?option=com_content&view=section&layout=blog&id=1&Itemid=81
Hi do you have to re jet or adjust carb's after fitting this type of exhaust system i have a se1996 thanks Gray
You can take the baffles out completely :)eek:) leave them in :)cool:) or add an extra set to keep the sig other unruffled :))). If you need still more, opt for the Torq Monsters and let the Screaming Eagle crowd wee themselves:p:D
Hi do you have to have the carb's rebalanced or new jet's after fitting one of these systems thanks Gray
