1 - 3 of 3 Posts
My 92' Aspencade overheats:eek: no matter the ambient temp only it takes longer when tempurture is cooler and less time when it is in the 70's or 80's. Any ideas where to start looking?
Have you checked coolant levels? Flush the system? Pinched to blocked hose? Something blocking the radiator? Checked the cap? After that it goes to the thermostat. Good luck and ride safe..
What two whel wing said, some times your coolant lever will be low, you could also have a bad cap, tha is the easy stuff to check, do that first.
1 - 3 of 3 Posts
