Bike was running fine all summer. Took bike out the other day, went to give gas and bike stalled out. Bike will idle however as soon as you give it some gas, it will sound like it getting no gas and stall. I first checked the gas filter. Not clogged. I even ran a straight hose from tank to pump and bike did same thing. How can you tell if it's a problem with either the pump or the fuel pump relay? I want to test the output of the fuel pump as per the shop manual but I don't know where the fuel pump relay is. If the relay was bad, would I get any voltage to the fuel pump? Thanks for any help.
