I have a 87 Goldwing. End of last season, I had a problem with bike stalling, then hardly run. Felt like it was running out of fuel. Took bike out today and ran check of fuel pump. It's pumping fuel fine. Filter not clogged. Bike running rough. While bike is running, I can remove both right side spark plug wires and bike runs the exact same. If I remove either of left side plug wires, bike stall immediately. I checked and I am getting spark at both right side wires. I removed plugs on right side expecting them to be dripping with gas. Both plugs were dry. I removed the fuel line and the "T" connection off the pump and ran a rubber hose from fuel pump to gas inlet for right side carbs. Bike started but it's still only running on left carbs. My question is how is gas getting to left carbs when I have that T off and just a rubber hose going into right side inlet? What could cause both right side carbs getting no gas?
