My GL1200 has a problem with low power upon cranking the starter. I put it on my Batt Tender overnight and it holds charge, then the bike starts and runs fine, but after a while if I stop and restart it, it cranks slow then barely just has enuf juice to restart. The previous owner told me he put a stator in it, and a battery, but then it sat for awhile as it needed a cylinder head. I have like 12.9 volts at idle, around 12.2 before starting the bike, and like 13.8 at 3000-3500 RPM, anyone know what volts should be at 3500? Thanks. Im thinkin battery?
13.8 should be good enough to keep the battery charged. If it is only starting hard when hot, you might have a bad starter.
No start in the morning= battery
No start after being ran and hot= starter
My bike does the same thing with starting. I also think it the starter and have already ordered a new starter and while I am at it I am putting in a new stator. But my situation is a little differernt in that I'm trying to fix all problems before using it in the USA. Lonewolftx said it well. Saluhispeed gave good information. Good ground to the starter is always important. Eric
I have had this problem with several bikes and I agree that it sounds like the starter. My question is, can you get the starter off an 1100 or a 1200 without pulling the motor. So far, the only thing I don't like about these bikes is the fact that you have to pull the motor to work on anything.
I am a newbie to the forum and i have a new to me 87 GL 1200I. i got it a few days ago and the first day i had it i started it at least 8 or 10 times as we had many stops on the way home. It never gave me an issue.
well the next day i got up for work and it started fine and i drove it to work with one stop along the way there as well. got to work and parked the bike. I go to get on it to go home and the battery is at 9V and wont start. I pull the pattery out and go buy a new one as i didnt knwo how long the old battery had really been in the bike.
Got to work this morning with a fully charged new battery and put it in and the bike started fine and i let it run for a while to just warm it up. This afternoon i go out to check the voltage and the battery says 12.69V and so i start it up and its running. I check the voltage and it says 12.11V so i rev the engine and hold it at 3500RPM. the voltage goes up to 12.22V but no higher. this seems low to me. shoudl it not be a lot higher to charge the battery. while revvign at that rPM it never dropped below the 12.22V. Any ideas on what to start checking? I dont have an manuals or anything yet as i just got the bike. I could sure use some direcvtions to look before i try to take the bike on any kind of long trip like i have planned for next weekend. I dont want to get stranded.... Thanks for any help you fellow GL riders can give.
Mike, I posted in your thread.
