I've had problems getting my 85 to run right after taking it out of storage for the year. I have removed the carb assembly three times now. The first time I just cleaned the jets, the second time I completely disassembled the carbs and soaked them for a day in carb cleaner, and the last time I took the carbs and had them ultrasonicly cleaned. Unfortunately the bike still runs the same, sounds like its running lean, backfires through the intake sometimes. If I partially choke it it seems to run ok, leading me to think it is a lean mixture situation. So while running it this last time I plugged the port in the air box that supplies the air cut off valve and the bike runs fine. After researching the web I ran across an article from Sabre Cycle stating the air cut off valve can cause the very problem I have. So I removed the air cut off valve and can't find anything wrong with the diaphram. Although the spring seems to be quite heavy for vacuum to pull it down. Some on forums say the cut off valve closes the slow jet air passage which creates a richer mixture to prevent backfiring when decelerating, but I never noticed any backfiring when decelerating while driving. I'm quite sure I have a lean mixture issue but don't know where to turn. I'd gladly change the cutoff valve diaghram, but I don't think its defective. Can anyone offer advice. Do you think if I just plugged the port in the intake box it would run properly?
