1 - 2 of 2 Posts
got hit on right rear quarter panel been fixing GW, question
running lights work fine on fairing but when turn signals are used running lights go out, any thoughts, hit on clutch lever and broke off, the switching might have screwed up, thanks for any advice
I have a 83 Aspencade, it is normal for the front running lights to go out on the side the signal turns on, and come back on when the signal is off. If you are talking about the rear, check the grounds, if the signal light ground is off the signal may be grounding through the running lights which would turn them off.
1 - 2 of 2 Posts
