should the plug going to the compressor have 12 volts to it all the time? checked voltage had none even with bike running, thanks
aaaaaaaarrrrrrrgggggggghhhhhhhh... I wish I had known that two weeks ago.No, it took me while to figure out the compressor only has power when you are holding the shock selector switch down and the compressor pump switch. I probably have wiring schematic if you need it.
