1 - 3 of 3 Posts
i have an 82 interstate that has dim lights both front and back, with the engine on or just the key on. the bike starts with no problem, i also have runnings lights i installed myself wired to a seperate switch, they work fine. i was originally thinking regulator/rectifier needs replacing, but im not sure. i changed the turn signal relay last nite and that did nothing. any ideas????
how good is the battery? clean the terminals, check the grounds, even the one on the engine. is the stator charging the battery
What does the voltage read at the battery terminals, bike running and not running?
1 - 3 of 3 Posts
