I have spent months rebuilding a 78 gl1000 that has been in storage since 1985. I have finally come to the end of the build yesterday. Turned on key, grabbed clutch, and hit the start button. The dash lights dim but nothing happen. So I turned the kill switch to the “off“ position and the bike immediately started cranking. I have a brand new fully charged battery and the “on“ part of switch just won’t engage the starter. I tested the spark with kill switch “off” and there was nothing. So it’s not like it is somehow switched around. Any help would be very helpful! Thanks.
My neutral light seems to be on regardless of what gear I’m in.
Also I had a vetter set up on it that I removed. So there is two plug ins that went to the lights that are not plugged in. If that helps diagnose the problem.
One more update hoping someone here can help. When I put a test light to the switch in the “off“ position, it lights up bright. In the “on” position the test light is super dim. So it’s getting some sort of power.
