i like my half cover from wingstuff. I hook the 2 elastic straps to the pegs. It doesn't take up alot of space either.
First, welcome to the forum. I use a Tour King which rolls up into a small pouch. It a half cover made of nylon and works great. Have used one for years. Water shakes off and takes up almost no room in the Wing..
http://www.tourkingcovers.com/shop/
UltraGard XL full cover. Also rolls up into a small pouch.
However, one should clean the bike(at least get the road dirt/dust off with a spray cleaner/polish prior to installing a cover.)
dust/dirt+cover+wind=moving cover=sandpaper=fine scratches
Make sure the one you buy (full or 1/2) is lined for the windshield.
Also suggest cutting 2 tennis balls and placing them over the folded "hinges" of the antenna prior to installing the cover. Will likely keep you from ripping a hole in you cover.
I use an Ultragard half-cover. Keeps the bike dry, the bird crap off, and doesn't take up much room.
I also use the 1/2 cover on trips. Takes up less space and still does the job. Thanks officer for the tennis ball tip, I'll find a couple. Maybe it will keep me from ripping my cover more.
1/2 cover works fine, a full cover is a nusiance to put on every day.
