1 - 13 of 13 Posts
The GL 1800A Owners Manual states oil change with new filter takes 3.9 quarts of oil and the You tube video made for GL1800 says 4.0 quarts. Which should I go with?
From the posts I've seen here and elsewhere 4 quarts is the name of the game.... I've always put in 4 quarts.
Pour it all in!
buy a gallon and pour it in, run 3,000 miles drain it out and repeat
Either way is fine. If in doubt, follow the manufacturer's recommendations. I wonder if they put 3.9 or 4 in at the dealer? I probably won't find out because I don't want to pay $100. for a 15-25 minute, easy job.
Ok Joe; I just gotta ask. Can I stop someplace along the way or do I haveta ride the 3000 at one time.:D
Just had to ask.:rolleyes:
Dump in Four quarts and Go !!
From the Northwest Corner
Ron
Ron
Run it the recommended mileage, 4K for #1, 8K ever after. Don't waste money or oil!
Change the filter-dump in a gallon and go!
4 quarts in my 1500 too. Seems to work for me. I like round numbers. My '03 Toyota Corolla calls for 3.9 quarts too. I put in 4 quarts of Mobil 1 and call it good. 107,000 miles so far.
There is absolutely no need to use a torque wrench for your oil filter. The standard is 1/4 turn after the O Ring makes contact, some filters state differently and just follow their directions. If you follow these guidelines, it is impossible to overtorque the oil filter. There is no oil change franchise (I.E. Jiffylube, etc) which uses a torque wrench. There are those that use one but it is what they are most comfortable with and that's fine.
The four quart amount is for a completely 'dry' engine as in after a re-build. Regular change and filter is 3.9 as some of the engine cavities never completely drain. Correct torque spec for the drain plug is 25 lbs/ft with a new crush washer.
My apologies. I read your post in haste and misunderstood. Yes, I use an impact wrench for my drain plug! Joking, please don't.
1 - 13 of 13 Posts
