I have a 2018 Goldwing DCT with heated grips. Using the special Kuryakyn ISO grips over the stock grips it takes way too long for any heat to be generated and then not nearly enough heat gets through two layers of rubber. Does anyone know if the stock heated coils are molder into the stock rubber grips or can the rubber grips be separated without damage to the coils? If the rubber grips can be removed without damage to the heated coils, then I believe that the standard ISO grips can be used producing more warm hands in the cold.
Any thoughts?
Ken
Any thoughts?
Ken
