Installing and upgrading, for me, is part of getting to know my bike. It was a long Covid winter, so I took advantage of some quiet time at home. I learned that the GW takes more courage to work on than my ADV bikes - but is not harder, just more time consuming. Fred's videos were a necessity. Organization is a must (and I am still looking for the place that extra screw goes)! But all in all, I am pleased on how things went and with the end result. Here is what I did (so far, lol):
Thanks to all on the forum for advice, guidance and support.
Safe Riding,
David
Accessory or Upgrade Name and URL | Notes | |
Tilting Motor Works TRiO front end | Reverse Trike Kit that provides the stability of a trike with the full lean capability of a motorcycle | |
inView Wireless Helmet-Mounted Brake and Turn Signal Light | Feature rich, helmet-mounted brake and turn signal light that provides motorcycle-integrated brake and turn signal indication as well as passive brake light illumination | |
TailBlazer modulated tail light | I really like it, easy install, great bang for the bucks! It did take some time to get the 2 modules (1 for each side) to fit under the seat. | |
PathBlazer headlight modulator | More great value. But I did have a problem. Essentially, the system modulates the high beams during the day. A light sensor turns this feature off at night. The instructions say drill a 3/8 hole and install the light sensor. Which I did. Next install a grommet (included) around the light sensor and fir it to the hole. Nope. The grommet they supplied was too small. I contacted Kisan and they were apologetic and discovered that their supplier no longer made the right sized bushing. &*%^$$%^@! I now had a 3/8 hole in my upper deck. I found a grommet at Home Depot that did the trick and all is good. | |
M1 DVR front/rear HD Cameras | Thinkware M1 Action Cam Thinkware M1 Motorcycle Cam | Dash Cam | Thinkware USA - see pic 1 installed on the front fender. A second cam is installed under the top case. Great quality cam, easy, but time-consuming install to hide the wires. It provides ride documentation and security, just in case. | |
PMD60 power module | Easy install, user programmable, makes getting power to accessories really easy. | |
Side case motion sensing lights | Stick-on, rechargeable magnetic lamp. I installed these with Velcro. They work great. They come on with motion and remove easily for charging. | |
Trunk & side case carpet liners | Trunk & Side case carpet liners. They just add a nice touch and keep things in place. | |
Traxxion seat bolts | Smart! Simplifies seat install. | |
Top case organizer | Top case organizer - plastic dividers that really help keep things separate and in their place without sacrificing main trunk space - | |
License plate compartment | License plate compartment - a simple, locking box behind your license plate DrySpec Stash Box. | |
ShowChrome fuse block isolator | Awesome device - gives you brake and turn output as well as keyed and ignition power! | |
Parking brake interlock | Why doesn't the GW come with this?! PITA install. Not hard, but time consuming. Lots of panels to remove. It prevents you from moving with the parking brake on. Smart! | |
Helibar handlebar risers | Helibar Risers. HeliBars® Tour Performance™ handlebar risers for 2018+ Honda GL1800 I am tall and used to adventure style bikes. It improves my riding position. Slow, careful, not-to-difficult install. | |
Traxxion Steering Pin | Traxxion Steering Pin Steering Safety Pin, 2018+ Gold Wing - Traxxion Dynamics - why take a chance? If you're doing Helibar Risers, install is a no-brainer! | |
Traxxion Steering Stem Nut | Ditto to above! | |
Traxxion Tie Rod Upgrade | Ditto to above! | |
Wildass seat pad | Well made, air adjustable. It is comfortable and gives me a little rise (the GW sits low compared to my last bike - a BMW R1200 GS Adventure) | |
Side stand enlarger | She's a heavy bike on soft asphalt! | |
EZpass Skin | EZPass Skin - hides the ugly white EZpass on a black dash. | |
Dash screen protector |
Grip Puppies | The Original and the Best - if you have big hands, they make the grips more comfortable. Heat comes through just fine. | |
Twisted Throttle D7 Lights | Simply amazing lights. The lenses provide both fog and distance and are benchmark for aftermarket lighting. I drilled the under-light cover for the second mounting hole and to pass the cable through (which I protected with a grommet) | |
Firecreek Light brackets | Very nice, very strong. Not cheap, but worth the money for heavy lights. Great support from the company! | |
Hopnel Tank Bag | Hopnel tank bag - Small, but handy! | |
12V accessory port | Super easy install (once you have the panels off). | |
Goldstrike drink holder | Its there when you need it and the mount can be used for other things (like a phone, etc.) | |
Fred Harmon s Maintenance videos | Fred Harmon s Maintenance videos - Watch Fred Harmon's Maintenance Videos for 2018+ Honda Gold Wing from Angel Ride Videos & WingStuff Online | Vimeo On Demand on Vimeo - simply worth their weight in gold. I couldn't have done all this without them. | |
Utopia seat backrest | Nice improvement in comfort and gives the passenger a small storage compartment. | |
Goldstrike highway pegs | I found these to give me the most reach and adjustability without sacrificing lean angle. They are a must for me because I cannot bend my left leg enough to get my foot on the normal peg. | |
Honda Trunk Rack | PITA install - be careful!!! Take your time!!! Document, document, document! | |
Honda Trunk Rack LED Brake Light | Simple install | |
Honda Trunk Sub Harness | Simple install, a must for above and trunk light | |
Honda LED Trunk Light | Simple install | |
Rear Fender Extender and Fill Kit | Super easy install - good bang for the buck if you ride in the rain or dust | |
Signal Dynamics Voltage Monitor | Cheap insurance if you run a lot of accessories | |
Tall Passenger Grab Rails | way better than stock! | |
Fob Protector | Just fob bling | |
Animal Whistle | Hidden protection (if they work, cheap insurance, if not, cheap mistake) |
Safe Riding,
David
