So....hello guys. I sincerely hope you can all help me.
I took on the project of doing some major maintenance to my Dad's 97 Aspencade GL1500.
I put on new tires, new brakes, new clutch master, upgraded the front forks, rebuilt/cleaned the carbs, changed the oil, flushed the radiator and asst. other simple maintenance jobs.
Regardless.....after reassembling it all I found that the bike will not start. No spark, no fuel pump turn on.
I have about 15 hours worth of time into diagnosing it all using the factory manual. I've checked every single sensor for proper function and all connections. NOTHING! I only had one slight fault that showed the 5th gear sensor as sorta stuck on? (the OD light ONLY comes on when it is in 5th, so I'm assuming that it is in fact working)
I even to the point where I decided the ECM somehow went bad with it just apart on my lift. I bought a newsed one locally and swapped it out.....NOTHING! Same result!
Anyone got a clue here what you would check to come up with an answer?
Don't say the emergency Kill switch as this was the FIRST thing I checked.
PLEASE HELP!?!?
PLEASE HELP!?!?
