Here I am again! I knew this problem had to get worse before I could diagnose it. The bike shut down without warning...again....ran out of fuel in the fuel filter. It would start up again in the past, but not this time! I think I've found the problem: when I perform the fuel pump test, per the Honda repair manual, by jumpering 2 wires in the ECU connector (while disconnected from the ECU), the fuel pump runs. I have power INTO the ECU, but no power on the Fuel Pump Control wire OUT of the ECU to the fuel pump. It scares me, but I'm pretty sure I need a new ECU...big $$$, I'm guessing. I can't find the part in Honda Direct Line...is it still available (from ANYBODY), and does anyone know the part number?
Thanks!
Thanks!
