i am having trouble with right turn signals front and back. sometimes slide works, most of the time does not. i have replaced several fuses, tried to replace back bulbs. how do i replace turn signal bulb on front right. thanks jes:(:confused:
1-flip up levers on each side of dash to loosen windshield
2-pull back rubber boot of side mirror, remove 1 screw on each side of bike phillips #2 driver
3-remove front chrome piece just under windshield (you will rock forward then lift up to free it from the tabs in the center.
4-use same driver to remove screw and lift out the lens
5-twist white plastic housing to expose bulb
and welcome to GWOF
First, welcome to the forum from Pa. Glad you found us. Looks like folks are chiming in here already helping. Good luck and ride safe..
I doubt it would be the bulb if it works sometimes unless the socket is loose of not making a good ground, probably the switch needs cleaning, try spraying contact cleaner in it and move it back and forth.
