Thanks William for the reply --- yes the bike is still running with new fuses installed -- is it a short that I can't find or is it a dioide hidden somewhere? Thanks again -- Johnhello hiburke, welcome to GWOF. when the lights go out is the bike still running? have you checked those old fuses or the charging system
Thanks -- Yes I loose all lights and dash except the brake lights -- and the problem is intermintent in that for no reason all goes out then after awhile it all comes back onDo you loose the headlight also?
Yes -- all goes out when I am riding - will check all wiring around handle bars this weekend and let you know --- Thanks again, JohnAre you riding the bike when they go out. If so check the wiring around the handle bars. Maybe something is pinching them. Or the wires are bad.
