1 - 2 of 2 Posts
Does anyone know the location of the neutral switch, the book shows it on the right side of the engine but it's not there. Harness goes behind the front cover of the engine, (behind the oil filter and water pump). Is access behind that cover.
On the 1981, it is located on the right side of the block just in front of the oil screen access cover as you mentioned. Part number 35752-300-020
On the 1983, it is attached to the inside of the front cover. It is a different part as the switch on the 1983 serves 2 purposes. It also is the overdrive (5th gear) switch.
The 1983 switch can not be used on a 1981 because the 1981 front cover does not have the necessary mounting bosses in the cover and the cams that it engages are not there.
I just put a 1981 engine in a 1983 and went through this. Hope it helps.
1 - 2 of 2 Posts
