Timing belts have arrived & parts to get front & rear brakes up to par. It runs but idles poorly so carb work necessary. Like to find an Ace locally to rebuild all four, but the master are retired or gone in Albuquerque so far! I've not scored a 1980-82 speedometer if anyone has one or whereabouts please help!
Thanks Tim Kennelly
277903
Tire Land vehicle Fuel tank Wheel Vehicle
I found the same problem when I needed my carbs rebuilt. You can't find just anyone who wants let alone knows how to do the work and set them up on the bike. I ended up biting the bullet. Getting all the parts needed, pulling out the repair manual and doing the job myself. After a small investment of a synchronizing tool. I was able to set the carbs. I have to say. Your ride is in beautiful shape for it's age. Good luck with the rebuild. Take your time, you can get it done. Check Ebay for the speedo. You'll find one there. It's called the pilot.
