1 - 2 of 2 Posts
The fog lights on my 2002 wing have stopped working. I've checked fuses & connections at lights. There is no power down at the light connections. I changed bulbs even though I knew that wasn't the problem just to eliminate them. Are there any other areas where I could check?
Under the left pocket where the switch for the lights is located is a relay. I would check to see if you can hear it move when you operate the switch. Just make sure to take out the pocket first because the relay is not loud. If you cannot hear it try holding it while you operate the switch. Sometimes you can feel the relay working.
1 - 2 of 2 Posts
