1 - 10 of 10 Posts
My original windshield has lots of scratches. I used Quixx scratch remover to remove them. The scratches are gone but in place I now have swirl marks from rubbing with the soft cloth that came with the kit. I decided to order a closeout tall windshield with vent from Dennis Kirk ($134 shipped). Found a youtube link demonstrating the steps in windshield replacement. Very clear and easy to follow:
I hope there won't be any problem when I actually install it this Saturday.
Quixx works fine on painted surfaces (I took some scratches off my ST with it) but the screens are a tad different animal.
When the windshield on my Wing was to scratched to see through, I just replaced it as I was going to try stuff that is supposed to take scratches out of plexi and lexan and I figured why bother get a new one.
If you read his post he Did.
HPham,
Windshield change is easy, just take your time & all will be well.
I did read the post, he tried to remove the scratches and the process only made matters worse and then he had to invest in a replacement windshield.
I replaced mine, as trying to remove the scratches with a product would only make visibility worse.
Quick fixes are not always the solution, sometimes a little money has to be invested.
I will replace mine this winter. Before I do I will take the new one to a shop that does laser etching and have them etch "Green Wing" in it. Then when I mount it I will put some white leds under it so the etching lights up.
lonewolftx,
what you're doing is very attractive, it has a fiber-optic effect as it will also shine around the edge too and where the vent opening is (if applicable). The white lights will make the etching stand out.
1 - 10 of 10 Posts
