I'm replacing the windshield on my 2000 GL1500 SE. When I tried to remove the 5 screws in the metal adjusting grommets, all of them are stuck tight. I took a couple of whacks at one of them with my impact driver, but no luck. Am I missing something?
I agree with thisMay be from age.. Try soaking them with a little WD40 or liquid wrench. That may loosen them up. Be careful not to strip the heads or get that stuff on the tupperware. Good luck..
This method has worked for me on several occasions.I have a DeWalt cordless screw driver with an adjustable clutch. If I find a screw that does not want to come out. I set the clutch on #1 position hold it in tight and let it hammer for a bit then move up to #2 and let it hammer for a bit and keep moving up till the screw finally come out. This has been working for me and I haven't stripped a screw using this method.
Ron
