1 - 12 of 12 Posts
On my 95 1500, the lowere lights on the lower cowl only come on when the blinker is on. I know there is a way to wire them so they stay on all the time. Can anyone poiint me in the right direction, on what I need to get to do this, and directions on what to do?
Converting the GL1500SE cornering lights into running lights. Firstly locate the relays for the cornering lights. They are located under the fairing lower panels. On some models they may be both on the same side. Follow the wiring from the relays to the connector blocks. On the bikes side of the loom locate the light blue/white wire for one side of the bike and orange/white wire for the other side. Cut these wires and the cornering lights will come on when the ignition is switched on. If you put a small switch oon each wire you can switch back to cornering light operation whenever you want. The wires draw less than one amp, so low current switches will do.
This is not my instructions..... mine was converted by the previous owner.
First locate the relays for the cornering lights. They are located under the fairing lower panels. On some models they may be both on the same side. Follow the wiring from the relays to the connector blocks. On the bikes side of the loom locate the light blue/white wire for one side of the bike and orange/white wire for the other side. Cut these wires and the cornering lights will come on when the ignition is switched on. If you put a small switch on each wire you can switch back to cornering light operation whenever you want. The wires draw less than one amp, so low current switches will do.
Here is the main thread on this mod. Here you will find what relays control those lights and others comments and support.
The cornering lights turned on full time does give more of a presence and makes the bike more visible, but adds nothing for usable night light. I rarely ride at night.
Bear in mind that the lower cowl lights on the 1500 were only intended to be cornering lamps and are angled accordingly. This makes them largely unsuitable for driving visability, but pretty good for being seen. Most States and Provinces in N/A have legislation that prohibits driving lights from being used in conjunction with high beams, plus they have restrictions on how much light (lumens/candlepower) they can put out and be legal.
That's true up to the the 98 Gold Wing, then Honda wired them as running light and not cornering lights, they came on when you start the bike. I don't remember if they went off when you turned on the high beams, I don't think they did.
Good call Joe. So in your opinion, can the older ones be upgraded with the lights from the 98 and above without a bunch of $$$.
I added the chrome ring from the SE model to my lights as you can see. They come with a rubber edging I thought the chrome ring added a little something but I think I paid about $50.00 for the rings
Just checked, they are $55.96 each side
08 RIM, R.
64281-MT8-771 001 $55.96
09 RIM, L.
64291-MT8-771 001 $55.96
I used the same kit that Joe did on my 93 Aspencade but wired mine into the turn signals and used amber bulbs. So I have amber lights on both front corner, that become turn signals also.
I like this idea. I have been riding around for the last 4,000 miles with one of my bulbs burned out as I haven't been interested in just replacing the burned out bulbs.
1 - 12 of 12 Posts
