Does anyone know if the '88 1500's headlight lens is held on only by the clips? Or is there some sort of adhesive?
I'm asking because the clips on the top are loose, I suspect that's because of heat at the top of the light has caused the "spring" in the clips to fade somewhat, also, the P.O. or someone put 55W/65W bulbs in there.
I see in the specs there should be 45W/45W;
But, on closer inspection of the rear of the light itself..stamped in the case at the bottom it says 55W/65W but at the top of the case it says 45W/45W.
Am I to assume that either bulb wattage is acceptable?
Oh ya, yesterday I ordered two Piaa (sp?) super white anti vibration H-4 bulbs. As called out in one of the threads here,but, I forget the wattage.
