Darkside
Darksider
1. Year of your 1500: 1997 GL1500 SE
2. List your tire name and size: Austone 175R16C 6PR
3. Run Flat or Not Run Flat: Non-run flat.
4. Miles on your Car Tire at your posting: 144 miles.
5. Evaluate your Car Tire's overall performance. 1 to 10 with 1 being the worst and 10 being the best: Rate a 7, planning on it doing better but to soon to do anymore.
6. Will you stay a Darksider? Yes/No: Yes, I will stay darkside.
7. Please list the size of the M/C tire your replacing. ie..."160/80-xx:
160/80B 16 (Avon Venom-x)
Wanted to get this up here for anyone thinking of going to the darkside.
The tire felt a little squirrelly at first but I think a lot of that had to do with the front also being replaced at the same time and I was really paying attention to any movement.
Now after 144 miles, much better.
It is defiantly quieter and my cruse will actually top out at 78-79mph instead of the 75 it used to(probably due to the height difference).
I put a Bridgestone Exedra radial on the front.
I put 2oz of Dyna Beads in the front and 3oz in the rear. I am pleased with them so far. I will for sure let you know if it stops tire cupping and wobble.
The tire looked to big but I went with what I had got off the forum and it fits fine.
2nd picture is the one that worried me, that is the tire still flat and what you see in front of it is the exhaust. I thought for sure when I put air in it I would have a clearance problem...no problem.
1900 miles on the tires now. Ride mostly 2 up, I do still like the CT, kind of wish I had gone bias ply on the front, may just be me but it seems like the radial is harder hitting on bumps. As far as curves I can not even tell the difference. I will admit that I was a little tense the first couple of hundred miles.
